Otter Works Alaska
- Other
- Other
- Other
- Other
Heh, then you know exactly what I mean with this stuff. Marinas just eat boats that don't have good zincs...Greetings Ben, nice, thank you. I do galvanic surveys for a living here in Alaska.
Sounds like you've got your hull nicely passivated, but the folks around you don't do nearly as well... good business opportunity! Given the kind of costs you're talking about, it might be worth looking into active cathodic protection; I'm all about doing things economically, but at that point, a few grand looks like pocket fluff. I have no experience with it myself, but I've heard of the Navy using them successfully, and met a guy who was doing high-latitudes sailing trips, and just loved his system.I daily see aluminum vessels with jet units with extensive galvanic damage at the water intake tunnels. These seine skiffs replacement values are $400,000 each, and damaged are running $50k to $150k a shot. Every one of these vessels is using old school zinc instead of aluminum anodes. The zinc anodes show no activity, and are completely encrusted as one might expect for a zinc anode being launched in and out of the water. And the number of anodes is down to one or two per vessel. I am seeking information about other aluminum water intake tunnels and how persons are reducing hull potential during maximum jet rpm. I figure if I am seeing this issue on 100 percent of the vessels here, others are seeing it too and have formed a successful mitigation response. I too live on a steel boat year round. I keep my style hull at -16mvdc and up to +30mvdc in reference to a millspec zinc test lead. The tunnel in the photo is about 20” in diameter. Check out more of the projects on Facebook: Otter Works Alaska
@Otter Works Alaska I hope you will contribute here and post on the forum! many of us here (including myself) are not on FB.Greetings Ben, nice, thank you. I do galvanic surveys for a living here in Alaska. I daily see aluminum vessels with jet units with extensive galvanic damage at the water intake tunnels. These seine skiffs replacement values are $400,000 each, and damaged are running $50k to $150k a shot. Every one of these vessels is using old school zinc instead of aluminum anodes. The zinc anodes show no activity, and are completely encrusted as one might expect for a zinc anode being launched in and out of the water. And the number of anodes is down to one or two per vessel. I am seeking information about other aluminum water intake tunnels and how persons are reducing hull potential during maximum jet rpm. I figure if I am seeing this issue on 100 percent of the vessels here, others are seeing it too and have formed a successful mitigation response. I too live on a steel boat year round. I keep my style hull at -16mvdc and up to +30mvdc in reference to a millspec zinc test lead. The tunnel in the photo is about 20” in diameter. Check out more of the projects on Facebook: Otter Works Alaska
