Glastron gt187 not charging...
dermaiky
Glastron
GT
Hey i just bought a GT187 but it wont charge the Battery. It only gives me 12,5 Volts even with higher rpm. I believe it should be more 13 ish or so. I want to check the rectifier first. Does anyone know where its located with the 250 HP Version?
Also my port side fuse keeps on popping on unregular bases..Any idea what could cause that?
I don't know that boat, but it sounds like you're looking at the right spot. Can you trace back the wiring from your stator or alternator to find the rectifier? Most likely it'll be first in line after your charging system.
I fugured it out. It was a broken rectifier....now the voltage is back to normal
