  • Reminder of the Thrust Vector and Lateral Thruster group buy through JetBoatPilot.....you only have Until AUGUST 31st. to get in on this group buy
GTS 207 has lost speed over the season
Chris112790
Lore City, Ohio
Glastron
GTS
I have had my 207 docked at the marina all summer, and am now topping out at around 30 mph at full throttle with just 2 people onboard. There is a decent amount of build-up/grime on the bottom of the boat - is it logical to think that is causing the issue?
genwrx
Houston, Tx
Glastron
GTS
Yeah could be a good place to start, I'd get it on the trailer or lift and get it scrubbed clean and check the intake grate as well.
Bill D
Tuscaloosa, AL
Some members have seen 10-15 MPH loss from growth on the hull.
Scarabpaul
Bradford, Ontario, Canada
you may also have a damaged wear ring or impeller, that would cause cavitation and loss of top speed... I would pull the boat out and inspect like genwrx suggested.
Shuck Water
Frisco, TX
It's the grime. Doesn't take much at all to kill top end speed.
Chris112790
Lore City, Ohio
Glastron
GTS
Thanks guys. I pulled the boat yesterday and plan to give it a good clean/inspection today before the weekend. A lot of people have told Simple Green works great to clean the scum off the boat... has anyone used it?
Chris112790
Lore City, Ohio
Glastron
GTS
I hope it's nothing that serious -obviously. I haven't done much with it this year only been out a few times, but each time I took it out it seemed to get slower. Hoping it's just the progressive build up.
Noel Cain
Glastron
GTS
Any update. I am having the same issue now, but dont see any build up at all. It runs full throttle when i first start it up, hits around 40mph, then the boat automatically cuts back power to run at 30mph only at full throttle. I have to turn off engine, then on again and same thing happens. Check engine light is only on at the power ignition, then goes away when its running. Super confused.
