jetboater40
- AR192
Hi!
We own a 2015 Yamaha AR192 (purchased used 3 years ago).
During that time, I never utilised the boat WOT due the presence of our kids.
I did however, recently chose to pilot our jet boat WOT without our kids and noted the maximum speed was 30mph at 7500rpms.
Prior to that, I was on the water for approximately 15 minutes before the WOT (the engine was therefore warm).
The air temperature was approximately 20 degrees Celsius and the water temperature, 17 degrees Celsius.
I read that the AR192's top speed is approximately 48mph.
The boat is not damaged and is properly maintained each boating season.
All equipment is stock.
Do you think the issue could be heat soak?
A drop of 18mph seems a lot for heat soak.
Thanks!
Thanks!
