Help! Can't remove driveshaft from LS2000
LS2000nKY
LS
I'm having an issue with the driveshaft when trying to replace the impeller and could use some much needed help. I removed the 4 bolts to the exit nozzle/bucket, then the 2 bolts vertical for support to hull, I removed the cables. The pump/impeller/driveshaft came out easily about 1 inch then stopped, I can't seem to be able to pull it out any further, I can easily wiggle it left and right but it can't pull it off. Is it stuck on something? I went through the cleanout plug and rotated the shaft by hand but that didn't help. Is there a step I missed? Is there something in the engine bay holding the driveshaft and preventing me from pulling it completely out?
Scottintexas
Corinth, TX (DFW)
glad to have you on board, update your profile with your location so we know where you're at,
are you running premix or oil lines, if you have oil lines with zip ties you need to change them asap,
The impeller should just pull out, nothing on the engine side holding it in,
maybe post a picture of your housing and what you've taken off, but normally it's just
4 bolts,
reverse bucket
steering cable
pull it out,
many people have problems with the shaft being "vacuum" sealed in place and have to use force, hammer, 2x4, tow straps to get it to release. Since you've gotten to move an inch I would think something else is binding it,
LS2000nKY
LS
Thank you for your reply, I tied a tow strap around it and pulled forcefully and it finally came loose. Next I'm installing new impellers.
piper84
LS
Same trouble I have a chain and a come along pulling on impeller housing. Moves about an inch and a half but when released goes back in place. All my research says nothing retaining the shaft and should slide out from Eng. coupling? Any ideas with this one. Boat is a Yamaha LS 2000 year 2000 Starboard side
Scottintexas
Corinth, TX (DFW)
Pull the other side out to see how easy it should be
piper84
LS
I do want to do the port side but may be the same issue. I think this boat has never been done before with impeller and ware ring replacement.
Scottintexas
Corinth, TX (DFW)
If it was me I’d try to remove the other side so you can see what you’re dealing with
if not, I’d pull it tight with the come along and the tap it with a hammer or put a impact wrench or something on it to vibrate it loose
Scottintexas
Corinth, TX (DFW)
Maybe check in the boat to make sure the intermediate bearing isn’t moving rearward with the shaft
Hoppy
North Platte, Nebraska
LX
Looks like the driveshaft splines are stuck in the midshaft bearing. I would gess the movement your getting is the midshaft bearing rubber and the engine compartment wall flexing. I think I would look at the midshaft coupler in the engine compartment and see if it is moving with the driveshaft when you pull on it. Some people have resorted to cutting the driveshaft then replacing the driveshaft and midshaft. I would try and spray some penitrating oil towards the splines from inside the water intake tunnel. That however may not work as there should be two o-rings that seal between the driveshaft and midshaft to keep the water out and would also keep any penitrating oil out from that direction. Otherwise if you remove the engine you will see a pop rivet in the center of the midshaft coupler that could be drilled out and you could spray penitrating oil in the splines from the direction. You could also possibly thread and put a grease zerk in the hole the pop rivet was in and try and separate the midshaft and driveshaft with hydraulic pressure from a grease gun. You might also at any point with some tension on the pump/driveshaft try tapping the side of and rotating the midshaft coupler maybe that could jar the splines loose.
piper84
LS
I pulled the port side jet pump assy it came right out with a slight pull. However still trying to get the starboard side shaft out still hasn’t budged I the Eng mount bolts and opened the Eng to shaft coupling cover there was about a two inch gap between the mid shaft coupling and the mid shaft coupling. The mid shaft coupling spins freely with the impeller shaft but as I said earlier will not come Out. Retired military helicopter mechanic never encountered any thing like this!
Scottintexas
Corinth, TX (DFW)
piper84
LS
Finely got the shaft out but have to replace the mid shaft assy and a few other parts also have to do a bit of fiberglass repair. Jet drive chined to a tree truck hitched to trailer and there ya go. Any suggestions preventing this issue in the future.
Hoppy
LX
To prevent it from getting stuck again make sure the o-rings in the midshaft are in good shape, use some waterproof grease on the splines, and remove pump every so often to re-grease the splines
piper84
LS
Thank you for the info hopefully back to getter in a few days.
