Ronnie
- SF Bay Area
- Limited S
I’m camping with a lot of family this weekend and already on the water.
Last weekend both engines ran fine. Today after a week on the charger / maintainer I could not get the port engine would past 6000 rpm but the starboard engine still spins up to 7,600 rpm.
The port engine is also hard to start. And sometimes stalls and/or idles roughly soon after it starts. I’m not sure what it could be but I plan to do the following tomorrow first thing in the morning. 1. Check the oil. 2. Check the throttle cable. 3. Change the spark plugs. 4. Put duct tape around the intake part that used to hold the ribbon. I forgot the parts name, but it is hard black plastic and the factory ribbon/flame arrestor sits in it, Green hulk says that they sometimes delaminate and cause boost issues which result in low rpms, starting and idling problems. Green hulks solution is to sell a billet part with a new gasket . That won’t work for me this weekend so I’m going to go with duct/gorilla tape.
Anything else I should try?
