Help. On water. Running 30 mph smooth…
Just1more
Darien,il
Starboard engine shutdown. Will crank but not start. Port engine starts fine. Any ideas?
Just1more
Darien,il
Yep. I did that also. Going to try again in the morning. Made it back to the marina safely and need a drink. Lol
zipper
Boston Whaler
What were the water conditions, waves or glass at the time of shutdown? X2 on what @Julian mentioned above. You may have a safety kill switch alignment issue or a worn lanyard clip.
Just1more
Darien,il
Smooth waters. Have checked the clean switch multiple times and the kill switch.
rkluck
Powder Springs, GA
Those are the usual problems. To be sure you can swap the switches to see fi the problem moves.
Floridaman79
Brevard County Florida
FSH Deluxe
Sorry I am late to the party.. Troubleshooting the lanyard and clean out hatch switches is a straightforward proposition. The electrical connector on the lanyard can simply be disconnected and for the clean out hatches you can swap the connectors in the engine bay and if you start having problems with your port engine you know it's a switch.
Cobra Jet Steering LLC
Vendor
Florida
his timing chain blew
Liveto99
New York Hudson Valley
Also it sounds stupid but make sure the throttle is in neutral I have had that happen.
Vendor
Florida
it is the chain
Beachbummer
Houston TX
