4x15mph
- Downingtown, PA
Stock radio is an infinity PRV350 and the speakers are <garbage>. I want to keep the head unit, add an amp, and upgrade the speakers all for ~$500. I also want to be able to add a subwoofer later so I want a setup that would support that.
I have a 2018 AR210 and the battery is under the port, rear seat. It looks like there might be a piece of wood under the dash console intended for attaching an amp?? See picture.
Questions:
- Would this be a decent amp option: Amazon.com: Kenwood KAC-M3004 Compact 4 Channel Digital Amplifier: Electronics
- For speakers, should I look at the Polk MM versus the DB's. Here are the MM's: Amazon.com: 4 x Polk Audio MM 6.5 inch 2-Way Car Marine Audio Boat Motorcycle Coaxial Speakers 6-1/2": Electronics
Also:
1) Does anyone have a recommendation on this year boat on the best location of the amp considering the wiring
2) Where do I route the wires on this boat? I read about routing across the fuel tank and does this involve taking off the floor/cover?
3) Will I have to cut wires and harnesses to set this up or are there some standard harness that plugs into my current head unit or speaker harnesses.
4) Any recommendations on speakers and amps that fit the bill?
Questions:
Also:
