help with wakeboard sizing
All Seas
Austin, TX
So I rarely purchase things in person with researching the heck out of it first, but I walked into a sun and ski shop "just to look" and really liked a hyperlite state board they had. I talked to the salesperson, tried it on and away I went with my first board.
I am 5'10 about 195lbs size 9 shoe.
The setup they recommended (all pre setup) was a 135 with 7-10 bindings.
After I got home, I looked up the size chart and it states I should be a 140. I called and unfortunately they only offer the packages in a pre set configuration and would need the 10-14 bindings to get the 140 board.
So as a new wakeboarder, will the 5 cm really make a difference? What am I gaining/losing?
MidnightRider
Zumbro Falls, MN
Malibu
Wake
For a beginner I would definitely have recommended you go with a longer board size for that weight which would be more forgiving of slower boat speeds that beginners tend to be comfortable at. Having said that the HL State is a great beginner board that is built to be really light and fast and will perform better for beginners on the shorter side than other board styles. Another up side it is also a great “boat board” if you have a range of beginners (kids to adults) and the 136-ish size is typically a good size board to shoot for if you are trying to accommodate a range of rider weights. I guess I’d recommend you look at a longer board if you are the only one that is going to use it but if this is going to be a family beginner board, I may stick with this size for this particular board.
spatty99
Orlando, FL
Moomba
That definitely sounds too small. It will work, but far from ideal. You will need to ride faster, landings will be harder, and it will be a little more twitchy. On the upside, the board will be quicker to turn.
Jgorm
San Diego / Colorado river
Find a new shop or order online. That's bs. You can get any bindings with any board.
sethman919
Apex, NC
Yeah... i typically have a guy your size on a 142. I have a 135 for early teens. The hefty guys ride the 146. 122 for the little ones.
biffdotorg
Pelican Rapids, MN
I was lucky when I bought our first board that my local shop was willing to swap bindings for me. I wanted a board I could share with the girls. So first goal were bindings that fit us all, then I went bigger to accommodate me, more than them. They could ride a bigger board while learning. I needed it for my size.
I ended up with a Ronix 146 with 7.5-11.5 bindings. Surprisingly, we have been able to strap in kids to adults with those bindings comfortably. I would have never guessed anyone could make that good of a universal binding.
