Here she is!
dockevj
So anyway I’ve not had the time to try my new AR190 till today. It’s a dream to handle, it did put the CobraJetSteering super ultimate on before I even tried it out. From reading on here, and from the way it handled I’m sure it was the right choice. Do have a problem though. Speedo doesn’t work?? Anyone had same problem and knows the cure?
Maccam26
Winston-Salem, NC
Congrats! Enjoy the fun
Ajax
St. Louis MO
BDCACE3F-0E08-4901-B1E9-B865A8CB0542.jpegtry cleaning the debris out of the sensor. Little hole in front side of sensor.
dockevj
Thanks. I’ll give it a look
Dixie Highway
Daphne, AL
A 2019 still has a pitot style speedometer? Isn’t it digital on the Connext, or does a 190 not have that? If it does, then you have a paddle wheel on the bottom of the boat near the stern. Mine gets debris or sand caught in it sometimes, just spinning it manually usually cleans it out.
jEt_jAk
SoCal
AR195
Should be a paddle wheel like 2018.
2kwik4u
Georgetown, IN
my '17 is a Paddle Wheel.
it's easy to get the wheel out of it's pivot points and jammed. Had a rock in mine a few times. Also bonked it on a bunk once in a VERY wavy retrieval. It's on the starboard side of the boat, on the bottom, near the drain plug, but on the bottom of the hull. Spin the little wheel a few times and see if it reads on the dash. If the wheel spins freely, but doesn't register, open the manhole in the rear cleanout tray and make sure it's plugged in. If plugged in, then trace that cable through to the dash and make sure it's plugged in there. Beyond that I got nothing :D
dockevj
Thanks to all! Yup, it’s the little spinning wheel. I really wasn’t looking for something like that as I thought connext would be more like digital. Anyway I’ve made sure it’s spinning freely and hope to be back on the water tomorrow 😀
