yam240sx
- SX
Ok .. so I have decided to modify my air intake system , and im not talking about ordering the cookie cutter riva cones or pleniums filters / k/n or.... ribbon delete ( which i already have ) ... i have custom engineered 2 different designs that i have thought up and am about to embark on .. i cannot show pics because i have not done any work yet .. so try to bare with me as i explain : OPTION 1 relocate air boxes to sides and backward about 4 inches .. the port airbox will be totally relocated from directly under the engine lid to the side where throttle cable /body area ... , completely close off / silicone snorkle area on each box .. drill a 3' inch hold in the back of each airbox and connect a 3 inch section or elbow hose routed to where the flush ports are , there i will be removing and relocating the flush ports and drilling a 3' size hold for a vent ( there are some pretty vents caps on amazon , behind there will be a 3 inch hose going directly to back of air box creating a ram air pressurized air box ( now im no scientist but at 40+ mph at 3" diameter im sure we are almost at supercharger status !!! ... OPTION 2 ( non presureized less labor , less performance) drill x2 3 inch holes directly left and right of sight hole on engine compartment lid each hole will be capped off with a custom pretty vant cap .. behind will be copies of the factory fan blower elbows ( the black ones at the rear ) these will stay mounted tucked under behind the face of engine lid cover ... they will be facing startboard and port will be mounted at 45* directly forcing clean cold air AT not connected to each airbox ( no mods or removing of and air box) .. ... NOW do i opt for option #1 or # 2 .. taking a poll .....
thnx
thnx
