Hot water leak: solved
ldefoggi
Greetings everyone! And thank you in advance for your help! I’ve been out of town for the last few weeks and had my 2017 ar195 out all day yesterday and noticed a few things.
1. Cavitating BAD on take off. I sealed my pump last season, and installed a new impeller and wear ring. I could yank grown adults up on a wake board and the boat didn’t act like there was the extra pull. Everything was great, until I changed spark plugs earlier this season. Ever since, I can hardly get the boat out of its own way, much less pull a skier out of the water. The engine has TONS of power, like it’s overpowering the jet pump. Last month I had two adults and 1 kid plus one kid on a wake board and Yesterday, I had 4 adult and 3 kids in the boat, so weight may be an issue, but I had similar weights last season without the same cavitation. I’m considering buying a Luck 13 cone. It looks like I can install it without removing the nozzle? Thoughts?
2. Yesterday, I opened the ski locker to store an unused cooler and notice water was flooding in thru the drain plug. The water was HOT. I checked the engine compartment, bone dry. So I opened that drain plug and moved all my people weight to the back and the ski locker drained and started filling the engine compartment, then the bilge pump kicked in as designed. This was a continuous fight all day, and it seemed like I never got all the water out. Hot water indicated to me this has to be an exhaust cooling leak. This morning I opened the ports next to the clean out plug and found the lower band for the clean out port tube loose. I haven’t unscrewed the plate yet to get a better look but the initial look with a flashlight, everything else SEEMS ok. Thoughts?
Thanks again for your help!
If the water is HOT you have a leak somewhere on the engine. You will save a lot of time if you get the boat on the water and start looking for it that way as putting it on the hose generally doesn’t produce as much water flow into the engine. You can try it for the heck of it. You said the drain plug was not installed in the ski locker and that water was rushing in through there, then you said you opened “that plug” and water started draining into the engine compartment. I’m confused by that statement.
When you say the bilge was bone dry, was that the liner or the hull?
What about your pilot water outlets? Are they flowing good?
Your clean out plug is the culprit for your cavitation issue. If it was working before then something else is at play here.. don’t spend the money on a 13 cone until you get it back to where it was at. When you say the clamp at the base of the clean out tube was loose, please define loose, like hanging there because it is broken? More than likely you found the source of your cavitation here.
Have you thoroughly checked the impeller for any attached debris?
Thanks for the quick reply.
Drain plugs: the ski locker plug was open and the engine compartment plug was closed. I opened the engine compartment plug and water flowed in, which started the bilge pump.
When I first noticed the water on the ski locker and then checked the engine compartment, that area was dry, so I guess that would’ve been the liner that the bilge pump is located on.
Pilot water outlets all flow at idle and spray very strong at higher rpm.
The clamp at the base of the clean out plug tube was loose in that I could spin in around the tube, but was tight enough to stay in place. I took the tube out to clean it and I had to really work to get to come loose.
I’ve checked the impeller, all clear, no nicks or damage that I can feel.
I have the clean out port plate all the way out and removed all the old rusted hose clamps to replace. I’m about to reinstall all the exhaust parts and take it back to the water and look for an engine cooling system leak again.
Sounds like a good plan!
What about your clean out plug seals? Are they in good shape? Ever been replaced? Be sure that whole area where they seat is clean and free from any kind of spooge, including the walls where the seal will billow out to. There has been more than one person who has the clean out seals be the source of their cavitation issue. One guy with a 210 FSH down in Florida had a similar problem to you, all good until one day leaving the marina the boat would cavitate badly. He hadn’t really looked at the seals, just pulled them up and left them laying in the tube. When I suggested that might he his problem he pulled them out and they were visibility degraded, he replaced the seals and no more problem.
Have a good look down in and around all the hoses on the engine where hot water could escape from.. you may be able to find a source before heading back out to the water, but your best bet is when cooling system water pressure is at its highest which is when you are cruising. Since you have found rusted clamps in the aft bilge that could be a source of the problem.
Is this a salt water boat?
Please keep us posted, and best of luck!
Good morning! This boat was a salt water boat for about 5 years but since I bought it it’s been on a fresh water river. Yesterday I replaced all the band clamps on the exhaust. Took it back to the river to test some more but didn’t find anything obvious. I found a drip at idle below the exhaust manifold but couldn’t pin point it without a mirror and it didn’t turn in to a spray that could tell with higher rpm. I only ran the engine up to about 5500 rpm while I was over top of it with a flash light and reaching down the sides looking for a leak (I had a friend driving). I did find that there was a little standing water on top of the oil cooler and one of the top mounting bolts for it was corroded. But again nothing obvious when the rpm were up.
For the cavitation, weight seemed to be my major factor the other day. With just the 2 of us there was very little cavitation. I had rebuilt the clean out plug with a new seal last season but the tube still fills with water every time. The deck hatch is sealed really well and the water just drains out thru the tube to the thru hull near the jet pump. I’ve greased the clean out plug seal in the past and tried wax as well, primarily to keep the plug from seizing in place. Should that seal prevent water from coming through in to the tube?
The clean out seals allow water into the tubes. However there seems to be a fix ..
The question in my mind is, did you have any more hot water in the bilge? Did you have the same amount of water coming out of the hole and or out of the bilge pump while on the water?
If the engine compartment is dry, you next need to check the bilge port between the clean out plugs in the wet storage area. I bet you have a leak down there.
Hot water usually means engine cooling line is impacted after the engine. That is much more serious as there will be hot water pumping into the boat...
You may still have an issue causing the cavitation (and fully agree with @FSH 210 Sport on that path), but I would make sure the cooling system is secure first. The blow by on the plugs is annoying, but I have not found it to be critical. I'd make sure you don't have water in the lower bilge from a cooling leak.
Agree time to inspect EVERY clamp on all the hoses, common issue is they rust and fall off ,a good idea is to put on new clamps and back them up with a cable tie for good measure
Thanks. Thats where I got the idea to use wax.
Yes, still had hot bilge water, not as much as the other day, but I wasn’t running it as hard either. I’ll need to get back out there at idle with the water hose hooked up and use a mirror to see if I can find a source without starting to take things apart.
I had that opened up yesterday before going back out in the water. At idle on the hose I didn’t find any leaks but I did take that time to replace every band clamp there. 8 clamps on the exhaust (double clamped), the clean out port tube and a few small ones.
From what I can tell, the only hose with hot cooling water exiting the engine (aside from the three pissers for the oil cooler and charge air cooler), is the hose coming off what looks to me like the water pump, which goes almost straight back in to the bilge with the clean out plug and out the transom. I did not inspect that while under pressure as I had already resealed the plate. Thoughts?
The only water I could find entering the engine compartment with the engine running was a drip off the exhaust manifold, which I could not find with the engine at 5500 rpm…
Ugh. Stupid sealed plate... I replaced my sealant with weatherstripping just for that reason.
I am thinking you have a relatively slow but significant leak in that cooling line or its connectors. Under hose pressure some don't make enough pressure to come out the pissers, no less find a leak. That said, not very safe to hang off the back while engine going at speed (CO, plug blow out and falling off concerns). But I don't think it is big, or the bilge pump would not keep up.
All that to say: no idea yet how to test that or find it. Some have used baby powder back there, taken a spin, then seen where water was washing it away. That might give more clues...
I actually bought some wx stripping to replace the sealant also. It’s about an 3/16” thick and 1/2” wide so I think it should compress well with enough “give” to account for some flex in the plate.
What I’ll probably do is back it in the water one day without launching and test at the ramp, that way I can pop the plate up and I’ll feel a little better about having that plate up while the engine is running at higher rpm (higher than idle anyways…) to see if that cooling water line is leaking.
Ok so I found the source of the leak. My issue was the seal of the water inlet box just below the exhaust manifold. Evidently it’d been “fixed” on my boat by a previous ovenware. Lots of corrosion and old silicone/RTV. I have it all cleaned up and ordered a new gasket for it and a new exhaust manifold gasket as I had to remove the manifold to get to it. I was able to see this gushing leak by using a friends HD scope camera.
In the hunt for this leak, I replaced EVERY band clamp. So it’s a plus that I won’t have any issues with them in the future. I also put in a rubber gasket on the transom clean out plate so no more cleaning silicone gasket Everytime I open that up.
Anyways, I’ll get a couple new gaskets this week and let it rip next weekend!
