xoomer
- Cape Coral, Florida
- SX
I'm trying to install a new reverse gate cable on my LX but can't get one of the plastic fittings off (#1). I can turn it a bit but the whole connection (#1 +#2) turn together--not sure if that is a problem. However, the main problem is that the area is so small that normal wrenches won't fit so I'm wondering if I it is going to be absolutely necessary to remove the bracket (#3)--something I'd rather not do if I can find another way to get the fitting off.
#4 is the old cable so I might be able to cut if off at the back and then get a socket in there but it might be fairly hard to cut.
Has anyone come across this problem before and found a good solution?
