How to access 2020 165 head unit wiring
Gozills
165 ID
Just picked up my boat yesterday and got home late yesterday. With only a cursory glance I didn’t immediately see how to access the back of the kicker head unit. If it’s not an act of Congress, I want to install a remote between the two swim deck/ lounge area speakers. Any insight?
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
165 G
Completely unrelated because I don't have the newer model and it didn't come with a stereo (installed my own). So can't really help you on where it's located, etc.
BUT pro tip: go through every clamp you can see in the engine area and ensure all of them are snug. It's happened more than once that somebody at the factory forgot to tighten a clamp and then, catastrophic failure. You should check all the clamps at least once a year regardless. Every year, I discover a clamp is loosening a bit.
Gozills
165 ID
Biggest issue so far is whomever buffed my boat at the factory needs bamboo shoots driven under their fingernails😂
Fastjew
Denton, TX
SX195
Actually not too bad...just remove the four bolts along the bottom of the gauge cluster and it comes out along with the plastic tray under the windshield.
Cpt_Caveman
165 G
I’ve got a 2017 base model 165, and looking to install my own as well. Looking for information on finding switched power or not to worry about it, as well as getting details from someone who’s done this already. Any help would be greatly appreciated.
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
165 G
Personally, I repurposed the courtesy light switch for the stereo bypassing the ignition entirely. Now I can turn the stereo on/off regardless of the key setup. But I don't have any lights except the standard single LED they have pre-installed. It just turns on along with the stereo.
Cpt_Caveman
165 G
What amperage does the courtesy light fuse support? That’s definitely an interesting idea. I’ll have to look into fishing the wires back from the console to the engine compartment. I want to put the dual speakers by the back seat the same as the stock setup
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
165 G
I don't use the courtesy light fuse (which is only 5A). I have an inline fuse to the amp.
Running the wires through the driver side gunwale is pretty simple. I have my amp installed near the battery as well. I ran wires for the switch but also for the control pad for the amp too so that I could mount it on the dash.
