Ronnie
- SF Bay Area
- Limited S
This is a simple and inexpensive mod for those that think that the stock set up restricts air flow to much but don’t want to spend $50 on aftermarket velocity stacks.
First you have to take the assembly with the flame arrestors off the engine. You will need a Phillips screw driver to remove the two screws on the air filter cover and an Allen wrench to remove the four Allen bolts holding the assembly onto th engine.
Second determine if you want to preserve the parts of the assembly for future reinstallation or not.
Third get the rubber connectors that are installed under the flame arrestor elements out of the assembly.
If you don’t care about damaging the rest of the assembly you can drill or cut the 16 rivets out which hold the assembly together.
If you want to preserve the rest of the assembly you can use dremel to carefully cut the rivet heads off or simply use a small flat head screw driver to pull the rubber boots/connectors out of the assembly. Reassembly may rerivetimg or the use of nuts and bolts.
Once the rubber connectors/boots are free from the rest of the assembly, clean them off and install them in the same orientation they would be if they were still in the assembly (they slip on and no clamps are used or needed). These are the velocity stacks.
The cleanable / reusable Air filter seems by Riva and r&d act as flame arrestors for those of you who want to stay legal.
This pic is of my other waverunner with a 160 hp 1,052 cc engine which has the r&d velocity stacks ($50) and air filter ($100ish) installed on it (with the air filter tilted to show the element).
This pic shows the differences in size of the stock elements with the larger of the two from the fx 160. The rest of the pics are of the mod being performed on a 140 hp 992 cc mr1 engine in an fx 140. Both of these engines were installed in the 230 series boats.
