CrankyGypsy
- Tampa, FL 33615
- SeaDoo
- Challenger
wanted to give the box anchor a try on my 2005 AR230 but also wanted to be able to store it in the anchor compartment without folding or banging around. i ordered (www.metalsdepot.com has always been good to me) the following supplies:
*4-ft of 1/4" x 3" hot rolled flat steel
*2-ft of 1/4" x 5" hot rolled flat steel
*2-ft of 3/8" diameter round steel bar
*few inches of 3/8" of quality rubber fuel line
you might want to scale your box lengths back a 1/4" to 1/2" from mine to make it easier to get in and out of the compartment. mine fits a little too perfectly into the compartment - i have to mind it not to scrape the gel coat getting it in and out.
i cut two pieces of the 3" flat steel into 12" and two more into 11.75":
butt them together and weld them so the box ends up being 12" square:
i have a 120v Lincoln Flux-Core welder - it doesn't produce the prettiest welds, but they will hold just fine for this purpose. i was also having a bit of trouble with a bad wind on my wire spool that caused it to feed poorly at times, adding to the ugliness of the welds. i replaced the spool when it ran out and things were fine again.
take the 5" flat bar and measure 1" from a corner on the long side. draw a line from this point to the opposite corner - this line is going to be the base of the first tooth (mark the base). from this second corner you just connected to, measure 4.5" along the length of the steel. connect this new point to the very first point you made - this should get you a scalene triangle. cut this triangle out and use it as a pattern for the next seven teeth. remember to mark the bases as you go to save guesswork:
once your triangles are done, measure a little over an 1" from the corner that is opposite the base. connect the two points with a line (it will be fairly parallel with the base). cut this small triangle off the top and round the tooth out. once attached, 4 teeth go one way and 4 teeth go the other way: bevel one edge of the base of each tooth a little bit (doesn't have to be a lot) so it is angled. this will leave a better edge for butting up to the box sides. again, be mindful that 4 go one way and 4 go the other way.
using a welding magnet, butt each tooth against the box at a 45* angle. place the tooth so that it sits at least 3/4" from the corner of the box (note pics). if you build it to be 11.5" x 11.5" you will only need to measure in 1/2". tack each tooth in and then check boat fitment before making the final welds. note in the last few pictures where the round bar goes to mount into the boat. do not finish these welds yet or you'll have to grind them back out.
to make the bracket for attaching the rope, i bent the round bar using a torch, sledge, and anvil (or vise). measure 1" and heat the bar to a crimson color - bend this to 45*. measure 2.5" and bend to 90*. measure another 2.5" and bend to 45*. then cut it 1" from this third bend. i used a corner of cardboard as a pattern to check my bends quickly. find the center line of the box side for this bracket and mark where the two 1" ends will go through. center punch and drill. i'm all about overkill, so i threaded the ends and added a nut before welding:
cut 2 pieces of the remaining round bar between 4.5" and 5" long. the interior edge of my boat brackets measure 14.5" - place the bar into the unfinished corners of the anchor and tack them in so they measure 14.5" from outer edge to outer edge. check for fitment in the boat. the anchor should hang inside the compartment without touching the hull. finish all of the welds:
i sealed the anchor with galvanized spray paint and it has been holding up pretty well:
i'm thinking of taking it to a local Line-X dealer for a more durable finish (the local galvanizer wants a $350 minimum order and i'm not going to bother calling around in an attempt to piggy-back another order). cut a couple lengths of the fuel line and slide them over the round bar ends. this will make them sit snugly and softly inside the boat brackets. i also padded the hull with four small pieces of hydroturf at the points where the teeth can make contact.
with a sandy/muddy bottom in fairly smooth water, it set fast and held sturdy. i got in the shallow water and gave it the line a tug while keeping my foot on the anchor to see how easy it was to lift ...it was in there nice and solid. very happy so far.
WEIGHT: 18 pounds
WEIGHT: 18 pounds
