How to fit AR240 trailer in garage?
jman
Thinking about buying an AR240. Boat will probably be on a dock. Problem is I need to have the trailer (no boat) fit in a standard 3 car garage and still have room for 2 cars. Is this doable or will I have to look at the 21 or 19 ft boats? Thanks.
Betik
Frisco, TX
are you trying to store the trailer in your garage ?
jman
Betik
Frisco, TX
Oh that is easy then. You buy 3 winches and place them stratigicaly ( like on a the 2 by 16) and you host up the trailer diagonally. Completely out of your way and you still have a 3 car garage. I light my jetski all the time and I do it with one winch ( or hoist I guess). I can send you pictures if you are having a hard time get the idea
jman
Interesting. I’d thought the trailer would be too big. Please send pictures.
Betik
Frisco, TX
Nope it will fit diagonally on a standard 2 car garage , so on 3 garage should be peace of cake. You might have to be a bit careful with the garage door openers but there is a solution if opener because an issue
mark_m
Columbus, OH
I’m in a similar situation for 2021 -> 2026. My garage is 2 car but it’s deep.
jman
The deeper the garage the easier it should be. I measured the AR240 trailer and with tongue folded it came out to 22 ft 6 inches. The length of my garage is 21 ft, from wall to garage door. Trying to figure out easiest way to make up that 18 inches.
mark_m
Columbus, OH
This looks interesting....
Betik
Frisco, TX
so the video above has the general idea., but I would go with 3 hoists instead of single one. The reason is that you can control different angles independently.
there have been members here that have put their 240 on a standard 2 car garage. Mine is 21x19 and it fit the boat diagonally.
So the picture i send show my hoist that I use and the rail. I lift the ski at the front of the garage and then slide it to the back of the garage. I then let it rest on the platfrom I build for my bike and ski. I might make a video when I put the ski up for winter storage.
If you get the hoists placed at the conrner of your garage you dont have to worry if your attic can support $1,500lbs of steel of not. At the edge of the garage ( by the wall) the vertical 2x6 ( or 2x4) will carry the weight.
if you have the space on top of the attic, I would go up and run a (4x4) and bolt it with nut. If you do that the trailer is not going anywhere. It will look scare as Hell, but it is actually okay LOL
