brian86992
- Houston, TX
- FSH Sport
I have wake surfed and wake boarded off my 2020 210 FSH with three different speed control set ups:
Stock
It goes without saying that on a heavily loaded jet boat it's extremely difficult to maintain speed without a speed control system. Especially at slower wakeboard speeds, the boat is at risk of falling off a plane as your passengers move around or you make a turn. Our Yamaha throttles are especially hard to make fine adjustments to speed and anyone who's pulled riders behind their Yamaha jet boat knows the struggle. Using the Cruise Assist button offers little help while pulling a rider.
Perfect Pass (PP)
Upgrading to Perfect Pass was a night and day improvement where I had so much more time to focus on the rider and my surroundings than fight the throttles. However, I quickly had trouble with a major shortcoming of the Perfect Pass. Simply put, the control system does a terrible job of maintaining speed in my 210 FSH. While wakeboarding it failed to give enough throttle to keep the boat at speed through a turn. Then it would speed up and exceed the set speed after the turn was complete. The overshoot was so bad that pulling up a wakeboarder with a set point of 20 mph, the boat would reach 27 mph for several seconds before the control began to cut throttle. When it did cut throttle, the wakeboarder's line would go slack and the boat would fall below the set speed. I experienced these symptoms with the boat heavy and ballasted as well as with minimal people and gear and not towing a rider.
Here's a diagram of what a poorly tuned control system looks like. Take note of the orange overshoot curve. The flat line is the set point (20 mph) and the curve that exceeds this set point is similar to how the Perfect Pass acted on my boat.
I worked with the Perfect Pass staff to attempt to resolve the poor performance of the control system. I was disappointed that Perfect Pass was not able to offer any troubleshooting or software updates. To me, it seems that Perfect Pass may not be actively involved in updating/creating control algorithms, rather just packaging and selling something either outdated or universal. Perfect Pass did offer for me to return the system for which they provided a full refund.
Ridesteady (RS)
Before purchasing the RS, I called up Hydrophase to ensure that I wouldn't have the same experience with their product. I had a long and technical conversation with Justin which gave me comfort to move forward with the purchase.
Install
There are some similarities and differences between the install of the PP and the RS:
Same
Control module "brain" in console
Dash mounted display
External stick-on GPS
High quality hardware, wiring, connections
Different
RS connects to both key switch wires, RS just one
PP has one throttle module in the engine compartment with connections to both throttles. RS has two complete throttle modules in the engine compartment
RS has a knob to adjust speed and settings instead of just buttons
RS has cam position sensor inputs from each engine
Operation
The operation of the Ridesteady is extremely similar to the Perfect Pass. There is one key difference between how the PP and RS treat throttle input. On the PP, if you had the throttle set at any point above the required amount, it essentially ignores any additional throttle. The RS will react (then settle back) if you adjust the throttle while the system is at set point. I believe this has to do with the RS modulating the throttle input by a percentage whereas the PP provides a direct voltage/signal to reach the desired set point. Justin explained it to me at one point and I've forgotten the specifics.
A feature of the RS which I think is very clever is how it distinguishes what a "run" is and disables itself once you throttle down. As you throttle down it displays a warning and a counter that you're about to "reset" the throttle. At that point it stops trying to maintain any speed and this would also be how the unit logs rider time. I've never had to fight the control system while having to return to pick up a rider.
My takeaways that make the Ridesteady my winner
The RS is slightly more expensive than the PP but I will recommend it to anyone looking for speed control for their Yamaha and especially the 210 FSH. I may be the anomaly (or the problem is two weak TR-1 engines trying to pull a rider) for how well the Perfect Pass algorithm works but the Ridesteady cured my issues. That within itself is enough reason for me to switch. On top of that, the RS has several design differences that offer (to me) crucial functionality. Here's some off the top of my head:
- Stock, no 3rd party control
- Perfect Pass
- Ridesteady
Stock
Perfect Pass (PP)
Ridesteady (RS)
Install
Same
Different
Operation
- RS allows you to adjust control system setpoints. It is a physical impossibility to create a control system that will work well for all boats in all environments. RS gives you the control over:
- Throttle response
- Activation speed
- Overshoot
- When engaged, the Perfect Pass doesn't allow you to use throttles independently. You retain individual throttle control with RS. I use differential throttle frequently to position myself to pick up a rider so this is a big one for me.
- The control knob is much easier to make adjustments to the speed while occupied with other tasks.
- RPM mode is praised a lot on this forum and also booed as an unnecessary feature. Because the boat is light and underpowered, I use the PP or RS any time I'm cruising for long distances to keep us at a reasonable speed especially in chop. Depending on conditions, I usually find it superior to specify an RPM setpoint and let the boat react to wind, currents and waves. This just isn't possible with the PP and the RS makes it very intuitive. There is of course the benefit of running the motors at a synced RPM to equalize wear, fuel burn, etc.
