I am stranded a hour from home. No power to my gauges in a ar192. Help!!
Robby
I need help! Stranded with no power to my gauges on a ar192
Scottintexas
Corinth, TX (DFW)
@HELP
Do your engines work?
What about your radio and interoir lights?
Robby
Everything is good but when I turn the motor over no power to the gauges
Trm1765
Red Wing MN
Limited
Check your hatch cover to make sure the switches are tripped and cover is down good, make sure it is in neutral, and safety lanyard is in. Some easy things to check.
Robby
I have tried that as well. Thanks for all the help! Still stuck.
djetok
Edmond, ok
Fuse or a plug with power to everything but computer would be my guess
Robby
Yep my guess is computer
Robby
I have checked all fuses. The only ones are behind the engine correct?
djetok
Edmond, ok
You have no power to switches? If you remove the backrest in the bow in front of the helm you can gain access to the key switch and wiring. Maybe a wire is loose there
Robby
It will turn over but gauges never get power
djetok
Edmond, ok
swatski
North Caldwell, NJ
There is a large "blade" fuse on the wall/bulkhead in the battery compartment, I think. Check that one, too.
Robby
I did. No luck still stranded
djetok
Edmond, ok
If there are no loose wires and the fuses are all good. If it were me I might try disconnecting the battery for a few minutes then hooking it back up and maybe that would reset the computer. Did you look behind the helm for a loose wire?
Murf'n'surf
Naples Florida
Turns over but no start = safety lanyard
Pull it out and put it back in
djetok
Edmond, ok
From what I can tell is his ecu is not booting up, since he has no gauge power
djetok
Edmond, ok
@Jwiley had the same issue , I searched his posts for a resolution. I did not see any. Maybe he will chime in.
djetok
Edmond, ok
