chrisinslc
- Salt Lake City, UT
Just pulled my impeller off to switch to another that had been repitched and when I pulled the pump and shaft out the impeller was loose on the shaft. I thought the reverse thread would keep that from happening. How tight do you go when putting it back on? Waiting to hear from someone before I reinstall. I used the cheater bar and leaned in to it pretty good. Is that all you folks do?
