ScarabMike
- Green Cove Springs, FL
- Scarab
- HO Impulse
I have been getting some questions about the 25 hour maintenance. Here is what you need to know.
This is the first oil change for the Rotax engine. Most of the dealers I have talked to have no idea what oil to use, or they just assume that any 5W40 oil is fine to use. THIS IS FAR FROM THE TRUTH!!!!!!
Our engines are very different to other engines. They run at extreme rpms most of their life, and are always under high stress. Regular engine oil WILL break down, and your engines will lock up. Please make sure your service department is using a JASO-MA Certified oil. There are many brands out there offering this type of oil. Its basically the same as full synthetic motor oil for motorcycles. Its also known as 4T oil.
OIL FILTER BRP PART #420956741
These oils are extremely expensive. Some like the Mobile 1 4T oil is close to $10 a quart.
Now there is light at the end of the tunnel. There is an incredible oil that I have used with great success in my jet ski, and now in my Scarab. And thats the Shell Rotella T6 in the blue bottle.
You can get it at Walmart for about $29 for a gallon.
This oil is highly recommended by all PWC and motorcycle owners, and I can tell you its awesome.
Of course, you can also use BRP XPS oil, and stay with OEM brands.
