David Decker
- Atlanta, GA
- 242 Limited S E-Series
I installed a second bilge pump today with a float switch, wired directly to the house battery. I wanted this for peace of mind, but also because the stock configuration doesn't work well for boats that are stored in dry stack.
When I return to dock after a day of boating, I tie up and head home. The boat stays in the water until the marina re-stacks it the next morning.
For folks who keep their boats in dry stack, the stock bilge pump situation leaves two choices, both of which are bad:
1. Leave the house battery switch ON. The pump will come on every 2 1/2 minutes for the next week or two, until I can go out to the lake again (or until my house battery dies).
2. Turn the house battery switch OFF, in which case I'd be effectively without a bilge pump for about 18 hours.
My solution was a second pump wired to a float switch and directly to the house battery. Now I can turn off the house switch and the second pump will still run, but only if it is actually needed. It draws no current and the pump stays off unless there is water present.
In order to avoid the need to drill a 2nd hole in the side of the boat, I used this 3/4" dual-bilge "Y" valve with two integrated check valves. This prevents backflow if one pump is on and the other is off.
http://www.explosivepowersports.com/unified-marine-dual-bilge-y-valve-50052444/?gclid=CM3307-mhcwCFYkCaQod3HEA_g
