ralphsmithiii
- Tampa, FL
Wanted to find out if I'm heading in the right direction or if I'm going to set my boat on fire. I'm in the process of installing a JL Audio setup. I was considering trying to figure out how to get the house battery switch off the mounted panel and tying in the power for the JL M800 to it or running the stereo system off its own dedicated battery switch in case I'd ever need/want cut power just to it. I do have JL Audio's Marine grade fuse that'll go inline either way but want I want to know is if this battery switch will accomplish what I'm looking for: a dedicated switch identical to the factory house/start swithces: https://www.amazon.com/gp/product/B07D5PV84D/ref=ppx_od_dt_b_detailpages00?ie=UTF8&psc=1
I ask because I ran to West Marine today and they suggested I use this switch: https://www.westmarine.com/buy/blue-sea-systems--m-series-dual-circuit-plus-battery-switch--8646309?recordNum=45
While I'm not opposed to using it, it's much larger than my other factory switches and I think overkill for what I'm trying. The first one I listed appears to match the factory switches (from what I can tell) and thus, I'd like to go that route if it'll work.
I just want to make sure I'm not missing something with these battery switches such as not being able to support "x" amount of voltage/amperage for a single amp (JL M800) setup.
