Installing Tower Speakers
Tom Toberman
Burlington, NC
I have a 2014 Yamaha 212X, and want to install some tower speakers....Is this something easy to do or should I have it done by a professional? I am pretty handy, but am a bit nervous about drilling holes in my boat and tower. I am assuming with the folding tower that the wires would have to be exposed at the folding point. If anyone has done this and could share some pictures or offer advice it would be great!
Geiger41
Egg Harbor Township NJ
I got mine professionally done...BUT after seeing it, the install does not look too hard. (To mount the towers and run speakers) I will get you pics of the only holes they cut. If you can run wire and hook them up to the amp on your own then your good. If you cant do that stuff then may as well have everything done professionally. Get you some pics tomorrow
upperdeck
menomonee falls, WI
You got it right. The wires exit and reenter at the joint. It's really pretty easy. Add an amp and sub and replace your factory speakers while you're at it...
MOA_Chaser
Chicora, PA
It's not hard. You can get plastic grommets for the holes in the tower where you have to go around the joint, and there are different connectors you can get so that you can remove the tower later. Neutrik Speakons, etc. Any hole in the boat (if it's not there already) would be where one of the mounts to the tower ends. Look for that hole first, if it's there you don't need/want to cut another one. I did mine myself, it's not difficult, just take your time.
jawsf16
Definitely doable for a novic with the help of the board. Hardest part is selecting and obtaining all of the gear and install wiring.
Williamsone46
Lehi, UT
255XD
This is where I mounted mine. I love the fact that they are not in the middle where you be hitting your head as you walk through.
Tom Toberman
Burlington, NC
Thanks for the pictures @Williamsone46 and @geiger41 and everyone else for all of the comments! I got suckered into buying the Poparazzi this week so I may have to wait a little bit, but with all I will save on install I feel confident I can easily do this!
ShowAndGo
It's pretty easy. I did mine a couple months ago. Deciding on your components is way harder. : )
Just don't try to get too close to the end of the bar (at the swivel) - it's solid at the bottom. I can take pics and measurements if you need me too. (assuming my '12 AR-210 tower is the same).
Tom Toberman
Burlington, NC
Thanks @ShowAndGo , if you've got some pics and measurements that would be great. What components did you use and are you happy with them?
Tom Toberman
Burlington, NC
OK, I have finally found some time to install my tower speakers and amp....but I need some help again! I have wired up the amp and am getting power with no problem and the speakers work when I plug the RCA cable to the fixed audio output cables on the CMD6, which obviously isnt where I can leave them as I get no control over volume using these jacks! I cannot get any sound when I use the appropriate RCA jacks on the CMD6 and connect them to the amp. Any idea what I am doing wrong here? It seems like it should be so simple, but I have tried every configuration and just dont seem to be getting any output! Thanks for any help anyone can provide! @ShowAndGo;@williamsone46; @geiger41
Geiger41
Like I said before I got mine professionally installed b/c I am not the best when it comes to installations. So basically your saying when you put the RCA wires from the head unit to the amp, you get no sound....Have you checked the audio level on the amp. Some amps let you adjust the audio out level per rca jack. What kind of amp ?
kthrash
Madison, MS
Is this what you are looking at? so you get sound using 9/10 but not 3-6? I dont have one but I am going by the manual online.. make sure your preout settings are set to on and not off.. the non fading pair of RCA's is for a Subwoofer and will be listed as such in the PreOut.
spatty99
Orlando, FL
Moomba
@Williamsone46 What type and size of speakers and cans did you use in your 212X? That is exactly what I want to do, but I'm not sure what size and swivel mounts would work best.
Joe Chop
I need to do this too. Are the JL the only way to go? Or the wetsounds bar?
spatty99
Orlando, FL
Moomba
I'm in the process of installing a pair of Wet Sounds Rev 8 tower speakers (with swivel clamp). I'll post pics when I'm done, but for now I can confirm they that fit perfectly on the sides of the 212X (like Williamsone pic), up and out of the way and protected from the elements by the bimini.
spatty99
Orlando, FL
Moomba
Here is a single pair of Wet Sounds Rev 8 installed on a 2008 212X. Used swivel clamps and placed to the sides of the tower just below the bimini. Don't hit my 6'3" head, protected from the elements, and can still just barely fit a wakeboard in the interior board rack. Sound is excellent. 20180425_195835.jpg 20180425_195829.jpg
