Jet boat won’t pull
Twocents
SeaDoo
Speedster
I recently bought a 1998 speedster twin engine knowing one engine wouldn’t crank. Dropped it in the water just to check other engine on the way home. It run but would only go about 5 mile hour acted like this wear ring May be bad but before I start tearing it apart was just wondering if maybe I should get that engine cranking and put it back in the water first. I have a starter ordered on its way but it’ll be the weekend before I can put it on and I’m about 50 miles from the water. Just hate to waist time and money tearing it apart for no reason or waisting a trip to the lake for it not to pull itself. Just wondering if someone could tell me if maybe it’s just not pulling right just because it’s only one engine. It try’s to pull then acts like it spins out like it coming out of the water but I know it’s not
zipper
Boston Whaler
Were the clean out plugs locked in?
Edit: See post #4 below.
jocolo21
252SE
Its a seadoo it doesnt have clean out ports, go to harbor freight and get a compression tool, its theres no or lowyou might have to rebuilt also i believe its carburated?, might also be time to check those too.
zipper
Boston Whaler
What a dumb ass...my only excuse is it was 5:30am and the coffee was still brewing. :banghead:
Cobra Jet Steering LLC
Vendor
Florida
could have a stripped power take off on the back of the engine where the drive shaft goes in, common issue on older models
Twocents
SeaDoo
Speedster
I appreciate the feedback. I had forgot I had posted on here. I put starter on this morning. It runs great with both engines running. But since I’m on here it started quitting on me like you just cut the key off.. I’m thinking it may be the cdi box getting hot. Does that sound like something y’all have run across. It’ll run great for a while then die and crank back after a few minutes. Like it’s getting ready to go out
MrBubbaGump
Thats the way seadoos are set up you cant really go over 5 mph on one engine... need both or idle on one thats it.
