  • Annoucing the SURFtember Surf Board Group Buy for JetBoaters.net members only Hosted by Transom Watersports now through September 30!
    BEST pricing of the season on the most popular wakesurf boards for jetboaters!
    - All in stock 2019 wakesurf boards on major discount, including the Popular Slingshot Coaster, Quantities are limited, only 15 buyer minimum
    You can dismiss this notice by clicking the "X" in the upper right corner >>>>>>
  • Announcing the 2019 Jetboat Pilot SEADEK Group Buy for JetBoaters.net members only! This is your best time to buy Seadek from JetboatPilot - you won't get a better price - the discount has now reached the maximum 30% already!
    So if you are tired of stepping on really hot snaps/carpet, or tired of that musty carpet smell - Seadeck is the best alternative out there! Get in on this now, or pay more later!
Jet pump Venturi
Spolly
HO Impulse
so Going back two summers I sucked up a small rock and wiped out my wear ring, I replaced and been having a blast since, however I been snooping around and ordered a solas 13/19 prop, but when when replacing I noticed a few chunks out of the Venturi, @only $70 I think iam replacing but curious if any of the gurus know how much 3 damaged fins would hurt velocity/performance.?
Dean P
Saint Petersburg, Fl
Chaparral
VRX
Good to know. Thanks for sharing. Enjoy...
gRobi
Germany erfurt
215 ID
I'm very curious, cause there is not much info on Solas in Scarabs. Whanted to change it in my 165HO but found nothing. Even Solas wasn't anble to help me.
Now im thinking of changing the props in my 215HO :winkingthumbsup"
Could you give some more detail? What is your engine, what exactly did you install (part umbers :) ) and it would be perfect if you could explain it's working better a little.
Many thanks :thumbsup:
