Looking for Yamaha 2021 212xe (or similar) Ski Locker pic
Austonian
212XE
Hi,
Does anyone happen to have a pic or video of what the OEM ski locker setup looks like?
Had a freak accident where a tree branch went through the locker & turned the insides into spaghetti. Pic attached of what I am starting with.
Detail C in this diagram makes the piping mostly clear & I ordered the parts.
I remember pulling out a white separator board & a rubberish mat. Looking to understand what part numbers they are & where they go with respect to the integrated ballast bag.
Thanks!
@Austanian Does your insurance cover all of that for a dealer to order and/or install?
@HangOutdoors thankfully, yes, & the claim process is complete. Only issue is that Austin shops are backed up & I am trying to get back out on the water without needing to wait on labor, if possible.
@Austanian Good call. I did the same with my steering cables this year. Wasn't going to wait and lose boat. Good Luck with repair.
Hi,
Thanks!
Rubber Mat
Surprisingly they dont list that white separator board.
Rubber mat is just a rubber mat - in fact, I would forgo it completely. I think it's there to protect the fiberglass from skis, but if you're putting ballast back in, all it does is attract grime and dirt.
@anmut thanks for the info & I was also staring to think that the $107.99 would be better spent on drinks.
Guessing the separator is there to keep the ballast bag from sliding into the pump machinery/piping. I should be able to rig something similar for that task, even if it's not a 100% match to the OEM bits.
$108! DAMN Yamaha!
I’ll take some pics from all angles for you tomorrow. I’m going to be looking for a possible ballast leak, so I’ll be digging around in the ski locker anyway. I noticed there’s a bunch of clear silicone around the my hose fittings. What the heck did they think this would accomplish?
@Mesa50 thank you! Exactly what I needed.
Next battle, partspitstop.com just sent an email saying all the piping/fitting parts are not available & Yamaha has not provided an estimated availability date.
@Mesa50 thanks again, I was able to get everything back to working order using your pics as a guide! appreciate you taking the time to post the pics.
Just fine with no rubber mat either.
