Lost bolt on Thrust Vector XL
Mrbruin2k
Currently at lake havasu. Have had XLs for 3 or so seasons with no problem. Mid day ton of chop on the lake after cruising for a few hours and all of a sudden left throttle wouldn't go to reverse at all, barely to neutral. Got to Naked Turtle dock and hopped under boat. Lost the bolt on the outside of the left side jet. Fin and bucket unattached on that side and no reverse on that motor. Anyone know what size bolt and length I can grab from Home Depot? Was going to try to go out for few hours in am before we leave to go back home.
Tried to use one of the bolts and washers from the table mount on the inside of my SX240 but it goes in too far and will allow me to reverse on that side but hits the steering and locks it not allowing me to turn left when I use the bolt on just the bucket. It isn't long enough to attach fin and bucket.
TIA
Gym
Falmouth, MA (Cape Cod)
@Mrbruin2k. I don't have your specific answer but hopefully @JetBoatPilot will come to the rescue. You could also try removing g the corresponding bolt from the other side to match it up. I used the blue locktite on all my bolts to prevent that issue. Good luck.
bumpy
Ashburnham, MA 01430
Cobalt
I think you should edit this post and add @HELP. The response will be very fast and accurate.
Gym
I think you should edit this post ans add @HELP. The response will be very fast and accurate.
Good thought @bumpy. I just wasn't sure if he was on the water or not but loosing boating time while on vacation is every bit an emergency.
Master-Spud
Plamondon, Alberta, Canada
Nautique
I know @JetBoatPilot sent me a replacement when I managed to strip mine. Not that that will get you back on the water right now. But when it comes to a more permanent fix I'd contact him.
Speedling
Cedar Lake, IN
SS
Zip tie?
Take off completely and finless!
Ronnie
SF Bay Area
I recommend removing one of the other bolts you still have and taking it to Home Depot with you as a sample.
Mrbruin2k
Thanks for the help. We were wet slipped and ended up having our other boat family head to the ER for a wakeboard tot he head and a couple staples. We only had my boat for 3 families so no time to get it onto trailer and find a bolt so we just skipped our last few hours of boating this morning and got an early start on the drive home in the 118 degree weather. Going to email @JetBoatPilot tomorrow to figure out which parts I am missing. Also the crossbar part looks pretty bent up as well...had to bungee the bucket and fin for the drive home.
JetBoatPilot
Event Sponsor
Event Sponsor
Vendor
Panama City, Fl
Sorry to hear that you had a rough weekend. Hopefully no one was badly hurt by the wakeboard. Call my office at 850-867-1410 and we will get the bolt, spacer, washer and nylon washer out to you. The new bolt will have a nylon patch lock on it so you should not have this happen to you again.
JetBoatPilot
Event Sponsor
Event Sponsor
Vendor
Panama City, Fl
@Mrbruin2k no worries. Thanks for your business!
sunbyrned
Louisville, KY
I know this is an old thread, but just keeping it current to say the same thing happened to me last night. This post helped me to figure it out though. I kept checking for sticks, etc. but sure enough, it was a missing bolt from the vectors. I just replaced the bolts on my 2012. Turns out the new bolts are shorter and the spring mechanism is a different design. I kept my old spring on because the new one wouldn't fit the old metal bracket, which I guess is no longer part of the new design. I didn't realize the bolts were shorter until now, which is probably why it fell out. If replacing old hardware, use all of it, spring, bolts, and all.
JetBoatPilot
Event Sponsor
Event Sponsor
Vendor
Panama City, Fl
We can help you with this if you will call my office at 850-867-1410
Thanks and sorry you're having issues.
sunbyrned
Louisville, KY
Perfect! I’ll definitely follow through with that. Thank you!
JetBoatPilot
Event Sponsor
Event Sponsor
Vendor
Panama City, Fl
You're welcome!
sunbyrned
Louisville, KY
Just got off the phone with Jetboatpilot folks. They went above and beyond helping me with my gear. Can’t say thank you enough! I’ll definitely keep going to you for my boat needs!
JetBoatPilot
Event Sponsor
Event Sponsor
Vendor
Panama City, Fl
Thank you and enjoy!
