Marvin willis
- Morehead city nc
The 2005 boats have the threaded drain plug.So you changed the thru-hull fitting to match the threads then as well eh? Or did the 2005 boats come with "screw" plugs?
Just checked amazon and they also have green, white, and red versions all for the same price ($18.99 I believe). I'll be getting the red one..Amarine Blue Cree LED Boat Drain Plug... https://www.amazon.com/dp/B00GDY6ETS?ref=yo_pop_ma_swf
Wait...why do you have water draining? I have an 18 year old boat and it's always dry as a bone in the bilge - except when water splashes over the sides into the cockpit which is very rare. If I had to drain, that indicates a leak somewhere!Looks good. What do you do with it while you are driving down the road? Just leave the plug in? I like to have my plug out so all the water from the bilge drains.
Mine will drain a lot from rainwater. I always leave mine unplugged on the way to the boat ramp as well.Wait...why do you have water draining? I have an 18 year old boat and it's always dry as a bone in the bilge - except when water splashes over the sides into the cockpit which is very rare. If I had to drain, that indicates a leak somewhere!
ok someone chime in on this.Can anyone tell me if this will plug right into a 2015 AR210 or do I need an adapter?
