natty
- Columbus, OH
- SX
I haven't seen much love on here for Lowrance installs. Yes I know they are the same company as Simrad but I've found the latest units from Simrad (go5 and go7) are not nearly as featureful as the HDS live series mostly due to the fact that I think Simrad go units are due for some updates... notably for me to bring the live sonar features to the go units.
With the constrained dashboard space on the 19 foot Yamaha's the wider HDS 7 fit in a better place than the somewhat taller Simrad go7 I was looking at. While I did like the more streamlined look of the go7 I don't mind the buttons on the HDS nor do I mind that it sticks out a little more in the dash mount. As a part of the install, I did have to cut a bit of fiberglass, but only three small places (1-2" cut upper left and right corners and a longer 6-8" cut on the bottom) as the connext screen original position already had a broader cutout. Hope this helps out someone else in the same spot as I was in determining which upgraded electronics they want on their boat.
