LS2000 Scupper Valve Replacement
swede4198
Exciter
I am trying to replace the scupper valve on my 2000 LS2000 but I do not have enough room to use a slip jaw wrench to remove the nut. I can only get about a 1/4 turn max. I need a socket or some type of wrench that will allow me to set it over the valve body. The only other rout is to start removing exhaust pipes which will be a big pain. Anyone have any suggestions?
4x15mph
Downingtown, PA
I don’t remember having a problem when I replaced mine in the LS2000. Can you consider just cutting it since it is plastic? I know I didn’t have to but just an idea
the MfM
Cold chisel and one tap with a hammer removed my old scupper valve. The plastic was very brittle.
jdjetboater
LS
Does the scupper have to be replaced with an OEM or will any aftermarket part work?
the MfM
