- Raleigh, NC 27614
- 242X E-Series
Every year we have a New Year's Eve party and it can get chilly later in the evening even with patio heaters. Especially when there is any wind. So I've had on my list for a while, screening in some or all of the porch. The plan I started with began from this Youtube video:
My initial goal is to stop cross wind, and to enclose the top screens to prevent all the hot air from escaping right out the top of the porch. Then I plan to work my way around the lower section. The challenge I'll have is that the side sections are 53" (and vinyl comes in 54" widths) - so the sides are ok, but the center section of the porch has 64" widths....so I'm not sure what I'll so there.
Once I got started and had a few pieces up, I then ran out of brass grommets and went to HomeDepot for more - and they were out, so I changed my plan some.
Initially I was following the video directions to the letter using the grommets. Below you see the sheets of vinyl being laid out and cut, then taped with ProGaffe tape and then grommetted:
Measuring the vinyl (I bought 20 gauge vinyl from Onlinefabricstore.com, I bought 18 yards at 5.90 a yard ($106.20) with free shipping.
For square sections it would be easy....doing the upper sections was a PITA!!! Here you see one of the top sections with grommets in place
Here is a close up of the grommets (one with holes cut, one with grommets hammered on):
Here are the of top sections in place. The one on the left only has grommets and nails holding it up. The one on the right has Screw Snap Fasteners holding it up (there are grommets in it too....but I switched to snap fasteners when I got to HomeDepot to get more grommets and they were out, and they now had snap fasteners). If I were to do this again, I'd go with snap fasteners only! Learn from me! LOL
Here is a shot of the door (I put the vinyl on the outside of the door as it was both easier, and the wind blows from that direction so I want the cross wood to hold it on more):
Here is a wide shot of the porch so you have some idea of what I'm dealing with. I'm not fond of heights and this ladder is the only one I have that allows me to get to the top without also going through the screening material. I'm glad the top two sections are now complete!
