Matching accessory switches and headlights
Craigz
Hi everyone
I'm looking to add some accessory switches for headlights and my boat lift remote. Has anyone found switches that match the stock ones?
Also if anyone's added switches can you post pics of the layout?
I'm also looking to add a couple headlights to the towers for those later trips. Has anyone added lights? Pictures? Recommendations?
Jacques
Doral, FL
HO Impulse
Hi Craigz,
I have the 2014 195 HOI, for that model I found the switch are built by Carling Technologies (http://www.carlingtech.com/toggle-switches-lt-series)
If you have Scarab, take a look at this file http://www.carlingtech.com/sites/default/files/documents/LT-Series_Details_&_COS.pdf, depending on what you are adding, you will find the specific part # you need.
I have been buying from this site without issues so far:
https://www.onlinecomponents.com/keywordsearch.aspx?text=Carling technologies LT
Hope it helps.
BR,
Jacques
Craigz
Hi Craigz,
Hope it helps.
BR,
Jacques
Thats perfect. Thank you very much. Those look like the exact switches in the 2017 as well.
