swatski
- North Caldwell, NJ
EDIT #2: Please note Post #20, below, with some clarifications about this thread.
EDIT: Please also check Jeff's @Cobra Jet Steering LLC clarifications/corrections of some inaccuracies in my post, below - in Post #3.
This past weekend, I was able to test a prototype of the new system that Jeff was talking about in the other thread:
https://jetboaters.net/threads/f-y-i-i-am-selling-out-the-remaining-fangs-forthe-ultimate-steering-systems.15856/
(offered at a nice discount for the first few users, too - thank you)
This new system adds oversized MEGA FANGs to the AK Magnum setup - essentially a single Ultimate per pump working in harmony with a pair of FANGs on steroids, and supported by an extra steering rod.
There a many older threads describing the basic Cobra systems:
https://jetboaters.net/threads/fangs-for-cobra-venoms-first-impressions.8960/
https://jetboaters.net/threads/2016-ar240-cobra-fins-magnum-ak-w-fangs-install-and-first-impressions-plus-ez-locks-refresher.11530/
https://jetboaters.net/threads/cobrajet-ultimate-fins-and-fangs-installation-video.9167/
The install is pretty much a breeze, same as w/regular FANGS - using the side force stabilizer instead of the direct mount onto the main fin (as in AK Magnum). Works even better if you can retain a trusted helper:
The MEGAs channel the water in reverse giving it more thrust and directionality - here is the original bolt holding the steering nozzle on the left (upside down), being replaced by the side force stabilizer bolt on the right:
And assembled on the boat:
These MEGA FANGs, just like the regular FANGS (but not AK FANGs), can be mounted as an independent system, without the fins (Ultimates or Magnums).
A distinguishing feature of MEGAs for the new keeled hulls (AK models): the inside MEGA FANGS will have a cut-out to accommodate the steering rods - OEM and extra (pic courtesy Cobra LLC):
(EDIT: This is a regular FANG in pic, the MEGAs are significantly larger - see @Cobra Jet Steering LLC post below)
The system is dynamite!
When going forward - the boat feels planted and turns extremely sharp w/the main fins in "down at speed" position (an adjustable feature). There is a pronounced power steering effect afforded by the two pairs of MEGAs - projecting forward off of each nozzle.
Turning is so sharp, one needs to be very careful not to be thrown off of the seat.
But here is the kicker:
This system works fantastic in reverse, adding both speed and directional enhancements. The stock reverse is barely functional - enough to stop the boat and kind of push it back but it is extremely sluggish and there is really not much directional steering capability (with the stock reverse). This is all completely cured with the MEGA FANGSs.
Here is a clip showing unbelievably improved steering in reverse (w/MEGA FANGs installed in a "keeled" 24' hull - 2016 AR240):
Testing is in reverse going into a long ~270 degree turn to PORT followed by a switch to ~180 degree turn to STRBD (at ~26 seconds mark) - all done without touching the throttles.
The results are very impressive. I wish I had a helper or better yet - a drone - to get some nicer footage. But even with that sloppy iPhone clip the results are very clear: a smooth turn in reverse is followed by a quick transition into the opposite turn - a maneuver that is impossible to execute with a stock boat.
Testing was done with both engines running constant ~4,000RPM without touching the throttles. Splitting the throttles can give extra zip to the already sharp functioning system, but I usually do not split my throttles so wanted to keep it real.
