McMark
- Monongahela, PA
Ive seen a couple of threads since I’ve been here regarding riding and/or getting started in motorcycling. I’ve had some sort of two wheeled vehicle since I was 6 and recently became two wheeless when we bought our Yamaha. So with this, I think we should start a repository of best practices for motorcycle operation. Feel free to add.
Avoid riding on painted lines. Especially when wet. They are very slippery.
Avoid riding in the center of your lane. Ride in the tire tracks of four wheeled vehicles. The center of the lane collects oil. Very slippery when wet.
Don’t pull directly up behind vehicles at a red light. Stay way left and back far enough to make an exit if you need to. Always consider a way out.
When approaching vehicles that could pull in front of you from a side road, watch their wheels. It’s easier to see a wheel spinning indicating they are moving forward than actually seeing the car edging forward.
At intersections always square off your turns. No wide sweeping turns.
Stay back a little at stop signs or intersection. Most four wheeled drivers sweep around the turn instead of squaring off.
Use caution at the outside of turns. This is where gravel and salt deposits from normal driving.
For the first hour during a rain, use extreme caution. Oil drippings make the road extremely slippery until there is enough rain to wash off the excess oil.
Don’t trust someone’s turn signal. Especially if you can’t make eye contact.
Practice mirror memorization.
Always do a head check before passing or switching lanes.
Square off to railroad crossings when possible.
One of our golden rules while traveling was to be done riding by 7PM to avoid a deer collision.
I could go on forever but I’ll leave it at this so others can add.
Ride safe!
Mark
Ride safe!
Mark
