mpecoraro
- Buffalo, NY
- 195S
I'm in the process of adding a second battery to my 195S. Picked up a group 31 X2 Power. Had planned on an Odyssey extreme group 31, but those are nowhere to be found. I've heard good things about the NorthStars and these X2s, so hopefully I'll have good luck.
I wanted to check in to see how most are mounting their battery trays on their 195S or similar boats. Searching the site, it seems 3/4 - 1" screws should do the trick. I'd prefer to mount it out of the way in the port side battery area, along with my Minn Kota 220PC. Any concerns with screws of that length or screws in the floor in that area?
I'm looking at a basic 2 battery setup as mentioned often on this site. Likely with a Blue Sea 9001e four position switch. Plan to use the flooded started generally and then switch to the X2 when floating, anchored, etc. Still using stock audio, but plan to upgrade down the road. I considered the m-Series 6007 switch, but again wasn't as easily available. I like the smaller size of the 6007 over the 9001e. Any concerns with either switch?
Thanks for your comments!
