austin65
I have a 2008 Yamaha AR230 with the following equipment
JVC KD-X37MBS Receiver
6 6.5 in boat speakers (two on swim deck)
1 10" Rockford M1 mounted behind drivers seat
4 8" Tower speakers
1 5 channel 750watt Rockford Marine amp
1 4 channel Boss Audio 3700 Watt amp (Not currently installed)
2 Rockford 200 x2 amps (not currently installed)
My question is how to control the tower speakers separately from the boat. the back of the receiver has a Rear, Front and Sub RCA ports. I have Roswell dual zone controller and hooked it up in conjunction with splitters and it worked, but it severely effected the quality of the sound. I took it to the local sound shop and they told me that I can't use it the way I had it. They told me to run the front channel rca's to the amp with the in boat speakers as well as the subwoofer RCA and then the rear channel RCA's to the tower speaker's amp and then use the splitters to make it so i have signal to both the front/rear inputs on the amps. They then told me i could use the roswell dual zone controller to hook to the receiver and the rear channel(tower amp) and contol the volume that way. I did that, and it all works fine, however i can't have the tower speakers on without the boat/subwoofer going.
Is there any options with the equipment I have? Or do i need a multi zone receiver? I would get one, but i'm limited on space to mount a new deck because of the space taken by the single din. I can't find any multi zone single din's that aren't a grand or more.
Thanks for the help.
oh the rockford amps are just extras. I don't think they can power the tower speakers unless I use them both. which means more wiring that i don't want to run across the boat. So i use the 4 channel Boss.
Thanks!
4 8" Tower speakers
Thanks!
