My 1st time to change my oil and spark plugs...
Tiger J
Santa Rosa Beach, FL
Ok, I want to do this myself this time. BUT the "Step by Step" link on the FAQ page is not working. Oil Change step by step
Does anyone have an old copy saved somewhere?
Also, I need to know all of the equipment necessary to make it as easy as possible.
Which spark plugs should I use? I have a '08 212X.
(The local Yamaha shop said it would be around $400 for the oil change... without new plugs.)
Does your boat have the 1000cc mr1? The other diy about a complete drain is also good, you would just stop when he goes to remove the drain plug.
markingyamaha part numberdegrees
port6P6006p6-R1321-00-0018.1'
starboard6P6106p6-R1321-10-0015.1'
filterKN303mobil m1-110
oil10w-30mobil one full synthetic
plugscr9eb6955 -reg
- iridium
ignittion key#
462​
key type YH 38 or X77
also, if you're ever in need of a part you can go to Yamahasportsplaza.com or some other parts site and it will pull a schematic and tell you parts,
I also started a conversation with you (top right of your screen),
