Chip F.
- Schuylkill Haven, PA
- SX
I'm in the gathering stage of my amp/ speaker upgrade and have almost everything sourced but I'm having difficulty finding a power/ground distribution block to feed my amp and a 12 volt sub panel . I'd like to find one that has an LED readout. Any suggestions? I'm going to use 4 ga. From the battery to the block then feed the amp with 4 ga and then the 12 volt sub panel with 8 ga.
For a 16' SX 240
Equipment:
1 Wetsounds syn 4 amp 4 channel
6 wetsounds WX -650 speakers - putting the two extras in mid cabin
I'm going to make the speakers RGB LED's myself. Hooked up to a music controller
My preliminary review of install accessories :
25 ft of power wire 4 ga. - if I go around engine compartment - how much would be needed to go over the fuel tank?
25 ft of ground wire 4 ga.
110 ft of 14 ga speaker wire - will that be enough?
18 ga remote wire
2 battery terminals
1 fuse holder with 80 amp or 100 amp fuse
4 channel RCA cable - using two sets of 2 channel - they have the shortest length (2 meter) I can find.
1 power/ ground block looking for one that has LED readout
5 ft of power wire 8 ga.
5 ft of ground wire 8 ga.
1 - 12 volt sub panel
Various connectors
Anything I might have missed?
For a 16' SX 240
Equipment:
18 ga remote wire
2 battery terminals
Various connectors
