nautica rib jet impeller size
bbar
Hi, Have a nautica rib jet. 10 ft. 520 lb. Impeller missing and no info as to what size should be in it. Any suggestions? Thanks.
Murf'n'surf
Naples Florida
Nautica is out of business unfortunately. I had a 12' Widebody with Yamaha outboard and loved it! You should be able to determine the proper impeller by measuring the wear ring opening. As for the proper pitch? It is probably fairly standard and same as a PWC with the same impeller.
