Need ballast help
Kyle Phillips
anyone know of a reasonably priced balast system for the AR195? And where would be the best place to put it for wakeboarding? Thanks!
Kyle Phillips
Awesome thanks! What are you using to fill them? Is there a pump kit?
jcyamaharider
Event Sponsor
Event Sponsor
Vendor
Rosebud, Mo
Blenderhead
Spout Springs North Carolina
Malibu
I second @jcyamaharider endorsement of the Attwood pump. In the absence of onboard installed pumps and ballast, this thing works very well. A little bit of a pain sometimes getting the pump to prime while filling as the boat is moving but otherwise awesome. Also pick up a power cable extension... It will save you a lot of cursing as a result. https://www.wakemakers.com/fly-high-tsunami-pump.html
jcyamaharider
Event Sponsor
Event Sponsor
Vendor
Rosebud, Mo
Also do yourself a favor and get the quick connect fittings.
jcyamaharider
Event Sponsor
Event Sponsor
Vendor
Rosebud, Mo
OptiLee
Columbus, OH
Whoa, How'd you find that? I just did a simple google search. What are the quick connect fillings you recommended as well?
Thanks, btw
jcyamaharider
Event Sponsor
Event Sponsor
Vendor
Rosebud, Mo
These go on the end of the pump. This specific one has a check valve so water doesn't come into the boat. You might have to reduce down to the correct thread size. You will also need about 15ft of hose.
https://www.wakemakers.com/fly-high-tsunami-pump-hose-extension.html
https://www.wakemakers.com/fly-high-pro-x-series-fitting-w744.html
Or just use the old fashioned ones.
https://www.wakemakers.com/fly-high-pro-x-series-fitting-w734.html
Depending on what type of bags you get:
https://www.wakemakers.com/perfect-union-conversion.html
https://www.wakemakers.com/launch-pad-fly-high-tsunami-pump-conversion.html
https://www.wakemakers.com/fly-high-pro-x-series-fitting-w730.html
OptiLee
Columbus, OH
Thanks! I need to just piece it all together!! :)
John Mcpartland
Vancouver Wa
+1 on 15ft of hose. I went ahead and ordered 18 ft the 9ft that comes with the pumps is not enough
OptiLee
Columbus, OH
So I got the Atwood pump, but does anyone have a recommendation for a 12v cigarette adapter to hook up for it? The wires are too short to just hook up to a lighter, I believe I need one with extended wires on it. Any insight?
Thanks again for all your help!
jcyamaharider
Event Sponsor
Event Sponsor
Vendor
Rosebud, Mo
Just splice in about 15 more foot of wire. That's what I did. Just make sure to make your connections water proof.
OptiLee
Columbus, OH
Forgive my ignorance, but how did you verify it was water proof? I was thinking about splicing it, yes - and then wrapping it with electrical tape but then second thought that wouldn't be water proof. Trying to prepare for the season...wah wah lol
Thanks again!
jcyamaharider
Event Sponsor
Event Sponsor
Vendor
Rosebud, Mo
I watched this video and then put my own spin on it, I spliced the 2 wire ends together by soldering them together and then put some dielectric grease and heat shrink tubing over the connection. I then used liquid electrical tape over the entire connection.
OptiLee
Columbus, OH
OK, so I want totally off with electrical tape. I didn’t know they made liquid! Awesome, thanks for the video and al the advice. I’ve got to order my cigarette adapter first but then I’ll tackle this. Thanks again!
