tenl
- 242 Limited S E-Series
The first time is good. three ballast will fill 100% and drain out . But wait a minite, i try to fill the ballast, the system not work,the screen ballast no up arrow or down arrow.
I must disconnect the battery,wait 2-3 minite,reconnect battery and start, the ballast system will working, but the arrow reaches 30-40%(Unspecified) will stop.I try to drain out the water,the system no down arrow,then i must disconnect the battery again, reconnect battery and start and drain.I don't know how much water he can fill. It stops automatically.It's a very annoying thing to do every time you use it.
