Need recommendation on VHF Radio.... Bimini in mind
afsigma21
I would like some recommendations on a medium level VHF in prep for Bimini 2019.
Right now I have a Uniden UM380 and a Cobra MRF45D in my cart on Amazon. I know next to nothing about these...
I have a couple assumptions.
1. I am connecting to 8' antenna mounted towards the top of the tower
2. I need an external speaker or headset
3. It will get wet, a LOT
Am I on the right path or am I scimping tooooo much?
seanmclean
Medford, NJ
I went with the Standard Horizon GX1700. It's not significantly more expensive than the models you're looking at, but has built in GPS which can automate a distress call should the need arise. You can get an external speaker to go along with it. Mine's installed under the dash, it's never seen a drop of water, though it is waterproof.
Tim Chies
SeaDoo
Challenger
Sean - where did you mount the antennae mast - I just bought the same unit and an 8' mast. Wondering about running the cable I have a 2018 242 Limited. Hows the leg room?
Thanks
Tim
twchies@gmail.com
Wisefam22
Lake Lanier ga
I havent installed my antenna yet, but I'm gonna run it towards aft of boat. Will have a ratchet bracket so I can loosen and lower for bridges that might have clearance issues.
If you ever do run from pinnopolus locks to chsrleston or the other way will most likely have to lower it.
Betik
Frisco, TX
I had the Standard Horizon GX1700 for the 2017 crossing. It took a lot of biting and the only complain I have about it is that the screen is too small to try to navigate with it.
I had a 8 foot antenna ( $40) which I mounted on the rail behind the captains chair ( see pictures).
Trim Tabs & fixed radio with 8 foot antenna were my favorite mods for the crossing.
on my next crossing ( probably 2020), I am planing on upgrading to a top of the line 8 foot antenna (~$200) with fixed radio that can connect to my chart plotter. My next crossing will cost me $2,000+ in electronics.
Note: on my return and inside the channels I hit a bridge with my antenna. I had a very loose fitting with a zip tie on the very top and it just got a bit scratched. Oversize it was fine.
seanmclean
Medford, NJ
Thanks
Tim
twchies@gmail.com
Legroom is fine, I don't sit and drive all that much, but have never knocked my knee on it. I followed the very good instructions that @Mainah generated: https://jetboaters.net/threads/my-trip-down-the-vhf-antenna-rabbit-hole.16678/
Here's a photo of my install:
