Need to be towed
jeff_s
I have an AR210
What has to clamped in order for me to get. A sea tow?
I sucked up a rope and need to be towed
Thanks
jeff_s
Well I got the rope out. But now that motor only goes up to 2000rpm?
Not sure what’s going on
jeff_s
I’m pretty sure I got all the rope out.
I just don’t know why that motor now won’t go over 2k rpm
It threw a 144 code which is low voltage
Shookie
Cary, NC
Not sure man, that sucks. I’ve done it twice! The hose you are talking about is in the lower rear of the engine compartment. It has a Y connection on it. I believe you clamp on the engine side where thereS a small rubber hose.
One suggestion is power everything down. A couple times on my boat I’ve had a random error. Turn it all off and back on and alarm clears. Perhaps there’s a warning or error since you probably stalled out the motor when it sucked up the rope.
jeff_s
Yeah we threw an anchor and are letting the kids swim. Hopefully the error will clear and allow the motor to run normal.
I appreciate your response
InmyElement
Upstate, NY
sorry we've all done it..i had to cut the rope to pieces utilizing the clean outs. I carry 2 cheap harbour frieght long nose vice grips in my tool bag to clamp off those hoses in case of a tow and a mask..haha. Definetly turn your main power off and give it a little while and try.
4x15mph
Downingtown, PA
Do you need to be towed or can’t you clamp off the one engine cooling and limp in on the good engine?
Gym
Falmouth, MA (Cape Cod)
If both motors run you can go up to full power on the good one as long as the trouble motor can idle. No clamps necessary.
jeff_s
I just got back. Limped it back to the dock.
I think I have a battery issue as well. Keep getting code 144
Thanks for all the responses.
My phone battery also died.
djetok
Edmond, ok
Is something in the stator?
jeff_s
Well I’m not 100% sure. I bought a battery on my way back home. My current battery is original and in its 3rd season.
It was very strange. After I cleared the rope, that motor would crank but not start. Then I got it to start but it was limited to 2k rpms
Then I parked, let the kids swim. when I tried starting, the other other would crank and not start.
When it finally started, that one would one do 2k rpm. But the other motor started and ran fine.
It’s got me baffled
djetok
Edmond, ok
It’s got me baffled
I would disconnect the battery and clear codes. Then I would pull the pump.
Liveto99
New York Hudson Valley
As long as the engine is running you can run the other at any speed. You could also idle both motors and be towed. If the motor is running it is forcing water and exhaust out and no water will go into the motor.
AboveTheBest
Bloomington, IN
Didn’t someone post about a year ago that as long as you push both throttles forward it doesn’t actually matter if the other engine is on...?
Bruce
Royal, AR
With both throttles forward it is less likely that you will push water into the disabled engine at 5 MPH.
Either both engines need to be running or one needs to be clamped.
djetok
Edmond, ok
It’s got me baffled
I was curious as to what you figured out?
jeff_s
1st off. Thanks for everyone responses.
I’m dropping it off at the dealership today as I’m still under YES warranty.
I purchased a new battery Saturday night. Sunday, took it out locally in the bay and it ran great.
Got it home Sunday night and when I went to flush the motors, I immediately got the same 144 code. Also port motor wouldnt start. Once I got port motor to start, it was again limited to 2k rpm’s.
It’s def an electrical system issue and as you mentioned earlier, could be a stator issue.
I also noticed when I cranked the motors last night, I could hear a clicking noise. Almost like the sound a grill igniter makes.
I’m hoping the dealership can find the issue.
This is my 1st issues I’m having. Also both motors have about 88 hours in them.
djetok
Edmond, ok
with the rope being ingested and the electrical issue happening right after. My hope was that you pull the pump and there would be something interfering with the stator.
