New Speedometer for 2003 LX 210
joe coleman
LX
Anyone know how to get a replacement Speedometer for a LX 210 2003 year?
I was told the part number is FOR-U822N-00-00 however, the only OEM is on eBay and it is $700.
Is there a compatible one that someone has used in the past that has worked?
Thanks for your time
Joe
4x15mph
Downingtown, PA
Faria makes replacement gauges. Make sure when you install the new one you use the 6-cyl setting on the back of the speedo.... its part of the setup/configuration
joe coleman
LX
Thanks - I'm assuming it is the SE9262A. Now just to find one...
4x15mph
Downingtown, PA
You have a lot of great choices and many of us replaced all gauges at the same time including tachs and fuel. There are some new designs and faces including LED lighting. So many choices. Good luck. BTW, you really don't need a speedo. You are either not moving or you are going 50 mph. Kidding - FYI, I found that when we were wakeboarding, etc., I could control the speed better by leaving one engine at max speed and then adjusting the other engine to dial in the MPH.
vmax2extreme
LX
I just purchased a 2003 LX210 and my speedo isnt working. Considering just getting a Faria GPS speedo and be done. Also replace out my yamaha depth finder and get like a Garmin fish/depth finder.
