Worth Every penny. just got a new to us 08 AR230 this year as well. looked! exactly like yours.
Steering fins if you dont already have them
Bimini top (if you dont have one this would be the first thing i would buy)
Perfect pass if you plan to do water sports
stoltz bow roller
board racks
maintenance stuff to check
clean out plugs - mine were seized in
steering cables
reverse cables
stoltz bow roller
board racks
steering cables
reverse cables
Glad to have you on board, is this your first boat ?
For a list of common issues with your model boat check out the link in my signature below,
be sure to check your scupper
be careful with your #3 spark plug
don't run the boat on one engine faster than "no wake" speed,
Number one! Number UNO! Without question.. Replace the scupper! They are plastic and they get brittle with age.... Most will snap once u try to remove them. If it cracks u have a 2 inch hole under the water line! Everything else can wait! !!
Yes, it's very nice. Well worth it. Quality product.
Another improvement I really like that gives me peace of mind....
This being an inboard boat with holes under the water line, I highly recommend an additional bilge pump(s) with a float switch, and bonus points for bilge alarm buzzer and/or indicator light when the float is triggered, so you are aware early if water intrusion is ever an issue.
Personally I think the teak gets a little busy looking if you install it on the swim platform and in the cockpit. We put the teak down on the swim deck then went solid with the pin outline inside. We also had them combine as many pieces as possible too (for example the gas tank comes in 2 peices, I had him make that one) again to try to not make it look so busy.
As for the quality? This stuff is legit! You can pressure wash it, doesn’t get hot, stain or anything. It’s super expensive (dare I still say over priced for foam) but it is really nice stuff.
I have the solid seadek with the pin outline throughout my boat. I like it. Can't believe i forgot about the damn scupper! replace that thing immediately.
Mine came with the Bimini, but having owned three previous boats that did not come with them, it is a must have. last boat i thought i would have to duke it out with the wife to spend the money on one immediately after buying the boat, but she told me I HAD to buy one. That being said i bought tower mounted biminis twice from ebay. I think the reborn brand and was very satisfied with them. simply take the cover off and stow when not in use and the frame stays up. will probably replace the bimini on mine with that type once the current one is past it.
I think this is the one I previously bought. there are a few different sizes of this style on ebay so take some measurements.
