ralphsmithiii
- Tampa, FL
Hey guys and gals,
Sorry for the super newbie question but I couldn't quite find it while searching. Where exactly is the waterline on the AR240s's, specifically the 2015? I may be really overthinking it but I'm planning on installing an external/transom mounted TotalScan transducer using a thru-hull fitting. I got the idea from @Julian but I like the location of the image attached. Using the image attached can you tell me where the waterline is at? The thru-hull fitting says specifically not to use it under the waterline.
