No Power (12 Volts) Accessories
Augusto David Rodriguez
ST. Agustine,Florida
I have a 2012 212X and I think when installing my new Wt Sound Radio , have a short. I follow the OEM Power wire Connector and have two cables( Power red and Black). I have read many issues with other boats. My doesn't have any 30 fuse near batteries and dual switch Battery selector, I have check on front inside the helm and ..NADA. I have a fuse boxes round shape above each engine this are Circular, and I have check fuses there. IF any one have found this"30 Amp fuse , it would be awesome to point me in the right direction. I just ran a temporary wire gage 8 with a fuse 30 amp all the way from Battery switch to the helm but I will like to used OEM power wires. Also I have the Manual and dent show any schematics/locations.
thanks
V/R
A. David Rodriguez
212X 2012"Per Diem"
thanks my fuse boxes are same place of the pictures but my are round and I have check the fuses. Near the battery I don't have any fuse box.My engine posit( Red wires are straight front batteries to the selecttor switch OF,1, 2 and All.
On my boat (might be similar wiring?) it's right near the battery switches along the wall between that compartment and the engine. It is screwed to that wall and is a small black box with an red/orange gasket to make it watertight.
Sort of looks like this: Fuse Holder
