No Wake Mode - button issue
tim2808
Spring Hill, TN
Anyone have their negative button on the no wake mode button not work? (+ works fine) Or work sometimes and not others? Or have to hold it down for about 2sec before it will throttle down a notch?
My 2013 Ar192 was acting strange all weekend. That button would work sometimes and not others. Also there were times where it struggled to crank, like the battery was low. But it was on a trickle charge all winter and it's brand new so that "shouldn't" be the issue. Then other times it would just start right up, no hesitation at all.
Just curious
with the older boats a low voltage issue would cause problems with the no wake, with your issue being not being consistent and slow to crank sometimes I might think to look for a loose ground wire,
Even thought the battery is new and on a trickle charger, I would still check all the connections and if they are secure, have it tested...... Sounds like a classic under-voltage problem of unknown cause......
I found my brand new battery to be low, and the connections were loose! I fixed both because it gave me a comm error too on first start up.
