No wake switch = check engine light
jtink
So 3 weeks ago I took my 2012 210 sx to the dealer. I was getting an intermittent check engine light at start up or low speeds.
They could not get the check engine light to come on, they tested the thermostat (s) and found both engines were running at 160 degrees and stats should open at 140. That must be your problem. Since there were no stored codes.
Took the.boat out for the first time after repairs, check engine light immediately, turn off wait then start again, all is fine.
Took the boat back to the dealer. This time they got the light to come on, then able to connect to software, said starboard engine no wake switch is failed.
They then switched the starboard and port switches and the check engine light followed to port side.
My question is, it sounds like this is the problem, however I see alot of people on here say the no wake switch is usually a sign of voltage issues. I have two batteries on a switch, I have tried running on either battery and on both batteries together and still have the alarm.
Thoughts....
tdonoughue
The Woodlands, TX 77381
How old are the batteries? Stock? Yank them and take them to the local auto parts store for a test.
Of course, the price of a switch is cheap. But I don't think I have ever seen an error code from a switch. There is a first time for everything, tho...
(my bet is still batteries or something)
jtink
Battery 1 (start) is one year old
Battery 2 (radio) is about 2 years old
tdonoughue
Ok. My bet is the switch.
(kidding, but those are too new to likely be the batteries; replace the switch, but I bet it turns out to be something else)
dscable
Crawfordsville, IN
I just bought a 2013 AR190 (from a forum member here) and have the same issue. I have the switch on order, but curious if you ever figured out your problem.
Beachbummer
Houston TX
If the problem followed the switch, it might be the switch.
Willusc
I know this is an old post but I’m having the same problem with my 2018 AR240. I’m getting a Starboard engine warning light. The alarm goes off every 10ish minutes even when not using the no wake assist. Boat runs great, no issues. Have also discovered that when using my no wake mode the rpms are not matching. Took to mechanic who ran a diagnostic and discovered error code 75 and 76 ”no wake cruise assist.” Has anyone figured out how to fix? I haven’t had my batteries tested and yes my boat has a large sound system on it. Never accord to me that could be causing it. I will see about testing my batteries (I have two marine batteries) but if they check out fine, any suggestions for my next move?
dscable
Crawfordsville, IN
Mine ended up being an electrical connection. Check all of your wire harnesses and make sure they are all connected and snug.
Willusc
I’m going to do that today. I found in another post they replaced their transistor. I really hope your fix will be my fix!! That’ll be the easier one!😂
David Martin
Punta Gorda
I think the best advice was already stated .........clean all connections on the back of the cruse switch and see if the switch has any gaps that you can spray electronics cleaner inside to clean the contacts. The dealer manuals wire diagram revels that that switched is looped wired into every dash switch before going back towards the engines and it also shares a ground wire with the entire dash. Yes it can cause a dash warning.....on my boat it gives a AL visual on my LCD screen if the switch runs into a problem............I have caused an AL warning on my screen by running in cruse at idle and throttling back on either engine (removing cruse one one engine only) AL flashes until I remove cruse on the other engine or shut down and restart.
Now this tells me the switch can also be upset if the throttle switch is out of sync or possible throttle switch is having trouble THIS little SWITCH loops all over the boat so finding the cause could be daunting. BUT THE ADVICE TO CLEAN WIRES/contacts is a vary good start..........then followed by switch replacement.
Just my .02 worth
jtink
Try taking your port switch and connecting it to starboard and starboard to port. See if the problem follows the switch. If not then not the switch.
Willusc
Just my .02 worth
Good advice. I’ll try that and see what happens. I’m away on work for a few weeks. When I get back I’m gonna give it a shot and let you know. Thanks!
Willusc
Great idea! I’m gonna try this too! Thanks!!
Willusc
Hello again. I’ve looked at the wiring and everything seems ok. I am a little confused when you mention switching switches. I looked under the dash where the plug meets the control but it’s just one plug attached to the control. Is there another switch you’re referring to?
FLJetBoater
There is some "no wake" wiring in the engine compartment on front wall to the side. I'm not sure if there is wiring on both sides or just one side and then it goes to both engines. But mine was on the port side near the battery wall. Inside it there is a small resistor that may have gone bad. That's what happened on my 2015. Replaced it and all good!
Willusc
I’m gonna work on it again this Friday and will certainly give your fix a try. I’ve found, unfortunately, that most fixes aren’t working for my boat because everything was changed on the 2018 models and newer. All the successful fixes are on 2017 and older. It’s driving me crazy! 😂
FLJetBoater
Here's the link to the original thread that I found when I had the issue.
Does seem to be mostly pre-2017 boats on that thread but hopefully this is something that hasn't changed for you!
